Aluminum heads >
Aluminum heads
Aluminum heads
Old 08-31-2011, 01:04 PM
OSO Moderator
BillR's Avatar
I had alum heads on mine motors for less than a year. They were coated and supposed to be OK in salt. Boat was religiously flushed with in 10 minutes of coming out of water using salt away. NEVER sat in water - ever!
Had to tear down and was surprised at all the corrosion in less than a year (about 25 hours). Don't use them!!!!
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 08-31-2011, 01:10 PM
+1, ive heard the same story from other guys.
Only way to make them last is to drain them, get the water away from the 2 surfaces. That or Closed cooling, Anti Freeze seems to protect them.
there is a reason Mercury doesnt run Alum heads on fresh water cooled motors, and only on Closed Cooling systems.
Boomer35 is offline
Old 08-31-2011, 01:17 PM
Wow Bill, I have EPD Aluminum heads on mine that Larry worked up before he got out of the biz and they are going on 8 seasons now and I have had 0 problems with any corrosion. I had to pull the port motor this year due to a leaky header that in turn killed the crank and rod and piston on one hole and the heads are super clean. These have been run in the salt 99% of their life.
Sorry you had such a bad time with aluminum, I am not saying you are wrong but what you saw has not been the case with my heads and what I have seen.
Slow Poke is offline
Old 08-31-2011, 01:20 PM
MarineKinetics
rmbuilder's Avatar
Bill,
Who is the manufacturer of your cylinder heads?
Regards,
Bob
rmbuilder is offline
Old 08-31-2011, 01:24 PM
I've heard of a few guys that have had issues using salt away and aluminum. Don't know if it's just coincidence or there's something there..?
HaxbySpeed is offline
Old 08-31-2011, 02:57 PM
BY U BOY's Avatar
4 seasons on my aluminum heads all in salt and flushed with fresh water nothing else and no corosion. I would build another engine with aluminum heads again with no problem.
BY U BOY is offline
Old 09-10-2011, 09:16 AM
One thing we may be forgetting here is stray current combining with salt and dissimilar metals on some of your boats. That may explain why one boat with aluminum heads holds up great and another doesn't.
Outboard motors have aluminum blocks/heads and seem to hold up very well. They do use some sort of coating in the water passages but its certainly not as tough as military spec anodizing.
I have a 1994 Yamaha 130 on my little tunnel and recently flushed the engine with a mixture of vinegar and water and it really cleaned out the water passages. Dont give much credit to the increase in water pressure as it was more likely due to having a different water source but look at the crap that came out of the engine suspended in the water.
http://www.youtube.com/watch?v=mKu8KkPFRnw
Mr. Demeanor is offline
Old 09-10-2011, 01:56 PM
Flushing with water and vinegar will definitely prolong your aluminums life.
Before
http://www.flickr.com/photos/65811281@N07/6133149278/
After
http://www.flickr.com/photos/65811281@N07/6132602179/
Old 09-10-2011, 08:37 PM
OSO Moderator
BillR's Avatar
Originally Posted by rmbuilder
Bill,
Regards,
Bob
Not sure, but I "think" Edelbrock..
My buddy (Rogman on OSO) had EXACT same issue. I think he got 40 hours before pulling. Both his motors had same amount of corrosion.
He now has iron eagle heads (I think) and after 3 years they look brand new.
I am not convinced on using alum heads in salt.
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 09-11-2011, 09:24 AM
The 180cc World cast iron heads work really well. if you are building a strong 347, the 200cc models are capable of 500hp with a good bit of cam.
JeremyAnderson is offline
