What's faster?
Official OSO boat whore
What's faster?
For a lower unit finish, which is the fastest? Polished, gloss paint, or buffed primer? I kinda suspect the answer, but I want to hear what other people know (or think they know )
Ginger or Mary Ann?
I guess a slightly rough lower unit. Going on the same theory as the sanded hull bottoms.
In theory, a slightly rough surface is better for reduced drag.
A smooth finish will allow [mostly]uninterupted laminar flow and induce direct water-to-solid friction. A slightly sanded or rough surface will 'hold' or grip some degree or water, a microscopic boundary layer, and create water-to-water friction -- the latter being less.
Yea, it was my understanding that the buffed primer was the fastest. The question is by how much?
Charter Member #38
So if you go with a slightly rough finish wouldn't you lose some prop efficiency ? You're introducing air to the prop/blade ?! I think it's going to be a very similar to nose coning a drive(you want to keep as much of an uninterrupted flow of water to the prop as you can) ?!
Actually, I believe the smooth polished surfaces are "sticky".
Charter Member #38
I think the differences would be so minor. Probably not even noticeable. Just like some prop shops will polish a prop and some won't both claim their way to be better ? Can they prove it ? Usually not. I think it's mostly just eye candy.
Now if you were going for a world record maybe a few tenths would be worth it.
On the nosecone issue, don't they usually want to smooth out the water before it gets to the prop ? With a rougher finish you'd be disturbing this water ? Which is correct ?!
Test is the only way and then it would have to be identical conditions(temps , water , fuel , weight etc.)
It's hard to say. I'm sure if you made calls to the manufacturers each would claim theirs to be faster ???
Play along Gary, because I'm thinking gloss black.
