New Engine Won't Turn Over
I don't think that is the problem but should be on the list of things to check! I do think the proper bolts should be used there.If you use bolts that have the thread all the way up then it could take less to shear!
![Cool](/forums/images/smilies/cool.gif)
Offshoreonly Advertiser
I am pulling the flywheel housng off a new engine tommorrow. I will try and check the clearance for you. Checking it is not a problem, remembering is the issue! My memory is toast.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
Here's an update - Pulled the flywheel housing and sure enough, the coupler bolt heads were hitting the housing. Put hex head bolts in and everything is great. There is probably less than 3/16" clearance in there from the head of the bolt to the housing. Live and learn, but it always seems to be the hard way.
That's made with a 3.875 stroke crank. I think it's similiar to the new cranks beings used in the GM 383HT crate motors. You use it with a 400 block or aftermarket (Merlin Motown, etc.).
A close friend runs one of these monsters on the jug... Motown block, 421 CID, all roller, 9.0's @ 150+/- in a 3000 lbs. (with driver) Nova. I like it!
It's a DART Little M block with a SCAT steel 3.875 crank. Last year it was a 415, this year it's 030 over so a 421. Had it out on Saturday and it ran real good but still needs a little tweaking. The weather's been so great here, I just want to enjoy it for a while. I'm tired of wrenching.
