K Plane pins?
While we're on this topic, does anyone have the Merc part no. for the flat washers that go on the old style (c clip type) pins?
Too Old,
C clip part # is 53-844229.
I still have a bag of those clips left if you want them. I drilled mine for cotter pins. I would keep soaking the hinge down with PB Blast. That stuff seems to work way better than anything else I have ever tried.
Charter Member #232
I remember a while back there was a post about those clips and some one got them from McMaster Car.
TooOld they are looking good
Jon
Jon
Put your best foot forward!
Unless they have changed, the McMaster Carr clips are light-duty and not suitable at all for this application. Buy the Merc part.
Hinge pins
I used a right angle grinder with a
2 to 2 1/2 inch cut off wheel and cut in
between ever single hinge joint.
Then you can get them out pretty easy
but you will still need a little heat.
I ordered the new pins through
Mcmaster Carr.
I ordered ( Nitronic 50 Stainless Steel).
It's better than 316, they use it for
shafting application's etc.
1/2 dia X 3' long $30.22
part # 9076K11
Cut it to your length's and put it
on a lathe for your groove for your
clips and your in business.
www.mcmaster.com
Good Luck
Cougarman
Mcmaster Carr.
part # 9076K11
www.mcmaster.com
Good Luck
Cougarman
Charter Member #232
Cougarman that is what I did. I however opted to thread the ends of the rod and use nuts
Jon
Jon
Pins
Audiofn,
On my previous boat I had the threaded ends
aswell. Cosmetically they look nicer, to work
on them I'll never have them again.
They were loctited on , as they should be.
Couldn't get them to release even with heat.
Ended up galling one and couldn't get the
other one loose.
And to top that, that particular boat
had one of those wonderful built in
fiberglass swim platforms. So you could
only take the pin out going toward the drive.
So I cut the little guy off and went to
the simple but effective clip method.
Cougarman
other one loose.
Cougarman
blue64drop
6
11-11-2002 11:46 AM
