EFI for everyone >
EFI for everyone
EFI for everyone
Old 03-02-2012, 12:08 PM
  #121
Originally Posted by HaxbySpeed
Holley TBI 550-400, about $2000 for everything including fuel pump and filters. There's a couple guys on here that sell a sandwich adapter to run an 02 bung in your exhaust, just drive around for a couple days while it tunes itself then disconnect the 02 sensor and you're done.
Do you think the 2k investment is worth it? I mean my boat runs fine, I am thinking reliability and fuel savings might pay for itself in the long run. Any additional benefits would be a bonus.
shaggy1970 is offline
Old 03-02-2012, 12:37 PM
  #122
It'd take a loooooong time before fuel savings would cover the initial investment. On a completely stock engine with a well tuned carburetor it's probably not worth it. If you have problems with cold or hot starts, stalling, burning too much fuel at cruise etc. it's very worthwhile but if it's running good I'd leave it alone.
HaxbySpeed is offline
Old 03-02-2012, 12:53 PM
  #123
Thank you so much for answering my questions. Do you think there would be any horse power gains? My boat runs great, it has about 370 hours on the motor. Its never had any problems, it starts right up and I think my fuel burn is normal. I guess I have a hole burning in my pocket and thought it might be a fun worth while project but if the experts don't think it worth the money, then I guess I will hang on to my cash. Thanks again for your time.
Old 03-02-2012, 12:57 PM
  #124
Would the holley efi work on a 502 with twin whipple supercharged carb setup?
Meaning that I would like to put 2 4BBL TBI systems with a coil per cilinder
diesel2fast4u is offline
Old 03-02-2012, 01:22 PM
  #125
Yes you can run dual TBI's with harness # 558-206, and the coil on plug is no problem. The only issue is the dual TB's are only good for about 1000hp.
Old 03-02-2012, 05:09 PM
  #126
Hi 1000hp is perfect. Which computer & tbi's would you use?
Can we order from you? If so pm your mail please
Old 03-02-2012, 07:00 PM
  #127
GPM
You could probably use 2 of these with the Holley ECM, pick the injector size that fits your HP. Run batch fire or bank to bank, self tune option should work as long as you run the 02 sensor. Just a thought.
GPM is offline
Old 03-03-2012, 06:41 PM
  #128
articfriends's Avatar
Lots of throttle body options, RMBuilder got me a good deal on a Scorpion throttle body for my last project, it only measured 1 5/8" tall, was rated to flow 2000 cfm and used a std holley pattern so no reason that throttle bodies should holdback hp on anything, Smitty
http://www.scorpion-performance.info...logGlue_Plugin
articfriends is offline
Old 03-03-2012, 07:13 PM
  #129
GPM
There are a lot of throttle body options, I believe he was talking TBI with the Holley ecm. The Holley TBI has the injector on the outside and limited size from what I recall.
GPM is offline
Old 03-03-2012, 08:32 PM
  #130
Alex, what do you think about on a B/B procharged setup ? also thanks for looks for that LS cam for me !!
ezstriper is offline
