EFI for everyone
#171
That's thinking outside of the box! Cool idea. I think some of the guys running PSI's were doing something similar. If you plumbed that into your exhaust at the right spot you'd probably reduce reversion potential as well.
#172
Rookie,
We are working on almost the exact same thing for these engines. Dustin Whipple is doing it as well on the engines going in his new OL. For example, you pulley the engine for 15 psi and only let it see 10 or so. What it does for the torque in the lower rpms is crazy. It also lets you make your target boost in any conditions. It is basically the same thing that Merc is doing with the 1075, 1200, 1300TT, etc. This is another reason that I would like to use the 555 since it has the ability and we all know it works well. As with yours, because it's controlled by the ecm, you can always let the engine see all of the boost that it is capable of making. The biggest benefits that I see are straightening out the distribution by speeding up the blower and increasing low and mid range torque by a considerate amount.
My biggest hurdle has been location for everything. I have an idea but it will require me to move a lot of my current stuff. I think it will be the best and most unobtrusive in the end, but it won't be quick or easy.
Haxor, thanks for the reply. I am trying to set up to run wet headers but there are a few hurdles to overcome. Not quite sure what to do yet.
Eddie
Eddie
#173
Sounds like you are on the right track and having some fun Eddie.
Dustin was in the loop back in 2009 / 2010 after we'd done this. A few of the Ford Powertrain engineers got a kick out of it too when they saw what we were up to.
Great to see you guys continuing the work and development in this area. It surely has huge potential, and its always fun playing with these type of solutions.
Back on topic:
Haxby, hit me up offline about the Holley set-up please. Email would be great.
Back on topic:
#174
Rookie,
Eddie
Eddie
#176
Rookie,
Eddie
Eddie
#178
piston ding
sorry to bust in, but I have a strange issue with a pair of 502 mpi"s I'm overhauling and converting the valve train to hp 500 spec's via Bob Madara. the weird thing is the port engine has a small ding on the #4 piston from exhaust valve, then after disassembling the other engine I found the same exhaust valve dent on #4 piston. I don't know the complete history on these motors, but they are stock 502mpi's. Seems very stange to be only one piston and on same piston on each engine.
#179
#180
I'm hoping that the intake that I'm using will help a bunch with the low speed distribution issues and I won't need to rely on the individual injector trimming as much. However, if I do need it, the 555 has unlimited ability to trim individual injectors throughout the entire rpm range.
On top of that, it has electronic boost control.
Eddie
