EFI for everyone
#251
The Terminator is their new entry level Throttle body EFI system. Holley was losing a lot of that market simply because their older TBI set-up didn't look as good as FAST, MSD, and PP. It works really well but looks just like an OEM unit. This is a huge market so Holley used some of the styling and design from their NASCAR spec throttle body and developed the "Terminator". It is the exact same ECU as the HP, but comes with a simple hand held controller instead of a laptop. You can use a laptop as well if you want.
#254
Efi
The Terminator so far is being setup for one tbi, however as you all likely know you can use an hp ecu and run 16 injectors. It works well that way with other brand tbi's for us. We are awaiting an order of Terminators now. Fun Fun
#255
Old style dual TBI's:
#256
I am intrigued about the Holley HP EFI system... but I don't see much in the way of gauges. Not that this is a deal breaker, but I want to keep working gages in the places I currently have cutouts.
With my current carb setup, I use Innovate's XD-16 gages for Air/fuel ratio. I like having this as a double check. At first, I assumed I could use one of the outputs from the Holley ECM to reprogram these gages to bring in a 0-5V analog signal. (The XD-16 can bring that in no problem and convert to AFR units). According to Holley, the ECM can't output analog signal. You can only use their digital gages...
I'm not against the digital gage concept, but the only 2 that Holley sells is a black background gage with a black or chrome bezel... not exactly a match for the marine world.
Since I already have gage cutouts for my AFR gages, I need something to take their place. The Innovate XD-16 has all the bezels and parts to change to white.
I also looked into using the LCD screen that comes with Holley - from what I can tell, this is not a dash mountable unit since the SD cards would not be removable. I also don't really like the idea of shelling out 600 bucks twice for a twin engine boat. That money would probably be better spent buying 1 or 2 Windows tablets with the holley software installed.
Any suggestions? thanks!
#257
Just FYI Allied Electronics has the USB (direct Replacement) cable for the HP( prob all?) ECU in 4.5 meter lengths ..... 15.00 .......m
http://www.alliedelec.com/search/pro...x?SKU=70099063
#258
Many thanks Alex!
Ok after reading this thread, asking a few questions here and there, and doing a lot of homework, I took Alex up on his offer and took the plunge and converted my motor to EFI. While I am not completely done since I've only run it on the hose at this point, the fact that I got to this point and it fired and ran instantly for the first time today gives me a lot of respect for this HP system and Alex's knowledge. I took a path less traveled and opted to convert a stack unit (I'll detail the whole conversion in another thread as it took me quite awhile to set this thing up!). Alex set me up with the Holley system, answered questions along the way, setup the base map and helped me troubleshoot from Vancouver while I'm in Chicago. I just wanted to give a shout out to Alex and thank him for the help in getting me to this point. Thanks Alex!
#259
That looks pretty bad a$$ with all those stacks. I know in road racing they work great because they are either on or off the throttle. But I remember that they can be a pain to adjust the idle speed on because now you have 8 little air gaps instead of one big one
#260
I hope Alex chimes-in here as he can really describe how this works, but I have the butterflies completely closed at idle. The IAC will then work to maintain the idle set point (I made a common vacuum plenum under the intake that is connected to each port and the IAC). Alex indicates tip-in can get a little tricky on these stacks which he adjusted for with timing. Also on this particular stack it was made for EFI so the butterflies are a tad smaller in diameter for better modulation compared to the mechanical version. I haven't run it under load yet so I anticipate there will be some fine tuning necessary. Time will tell.....
