Pvc
I have a HP500 with a 250 powercharger 1150 holley and merlin heads my question is under the carb on the carb adapter there is 4 pipe plugs 2 on each side can I run the pvc hose from each valve cover to these or is this a bad idea being that it is directly under the carb I thought there would be more vac. to help pull neg. crank pressure on the motor. Thanks EWB
Official OSO boat whore
I think you'll have too strong of a vacuum, end up with a diluted charge to the engine and would stand a chance of burning a piston from it running too lean. Just run it up to the air cleaner and call it done. If you really want, you can come up with some hardware store fittings or AN fittings to plumb it into the bottom of the air cleaner where it's a bit cleaner.
Ok i read this and wonder now.. I am about to put a PVC on my motor next weekend.. I have a 3/8 nipple on the rear of my carb in the baseplate and I was gonna hook it up there.. would I have the same problem..
I have a little bit of ol coming out my dipstick and the oil level is correct..
Travis
Travis
People get confused.
I saw it early this morning but chose to ignor it.
Guys, it's not PVC, it's PCV.
Positive Crankcase Ventilation.
PVC stands for PolyVinyl Chloride. Plastic drain pipes.
If you chose to attach it to the carb, preferably out side of the flame arrestor. Use two, one for each valve cover.
Toxic FORMULA
I had a 1988 Liberator with an OMC 460 King Cobra. It came from the factory with a pcv system. This also contained a valve like an auto engine to limit the amount of air you suck. Without it you could suffer a lean condition , and we all know what that can do
Later built a 540 Ford and used the same setup.
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
