Jesel rockers on Dart pro 1s
Racer
Racer
The problem you are having is not normal my dart 320 and my cnc 355 both have jessel on them and are fine but from what you are saying if i read right is the mounting pad is off to valve angle thats not normal.
Is the problem the same on both heads and on every valve tip?
Lorenzo Fast Flow Heads
Hulmville, PA. (215)750-8324
BTW: I have have Jessel on my Dart Pro 1's Lorenzo did for me too.
the AFRs will line up dead ballz on with no addtl work
ROCK ON !!!!!!!!!!!!!!!!!!!!!
I DON'T PLAY BASEBALL BUT I HIT ALOT OF HOME RUNS ...
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
Racer
Racer
Did you buy these heads new?
I was just at a swap meet and i ran into one of the guys from dart he new somthing about your problem and the plug problem the other guy had .
Give me a ring i maybe will be able to help you out .
You know the old saying its not what you know its who you know might be worth a try.
At least i might be able to get you hooked up with the right person to get this taken care of.
Gary 586-855-2807
Gary 586-855-2807
Yeah everything is brand new rite out of the box, heads came directly from dart and i personally picked up the rockers from jesel, ill give you a ring tomorow gary thanks
