89 Bravo oil reservoir leaks
My Friend has a leak at the bottom where the fitting is on the reservoir for the drive.It is the round style.I am assuming that there is a gasket or oring. Is this a common problem? Is it a simple repair?
Rob
Rob
Offshoreonly Advertiser
That is usually a cracked bottle -
![Frown](/forums/images/smilies/frown.gif)
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
That vintage is probaly a round bottle. If so, Merc has redesigned the deal and your pal needs to get the new design. It requires a new bottle and transom mounting bracket.
After replacing a couple of cracked round bottles I got the new design and haven't had any problems since.
Yeah, I got the round ones too. I replaced one and if (when) they go bad I'll upgrade. It is a bad design. Even if they don't crack it is a good chance that they'll leak because the sealing surface of the bottle on the inside is un-even.
Mongo
Mongo
BillR
04-25-2006 08:32 AM
