TRS vs BRAVO
No need to re-rig to a lesser drive, Konrad's 540PRS is a direct bolt-on unit designed to replace the TRS. It's 1.7" shorter from input shaft to prop shaft. This increase in propshaft height typically results in gains of 3-5 mph when compared to the TRS. 7 qts gear lube capacity, rated to handle up to 800hp.
With your motors sitting 2 foot forward, 3 inches higher, 200 more weight, more hydrodynamic drag, and needing an extra 100 ponies. Yea I would say even if a TRS could somehow hold 150 more hp than a bravo it would need more than that to equal to performance.
Yes, there's speed to be gained, Bravo to TRS but most gain is from the ingrease in propshaft height with the Bravo being about 2.5" shorter than a TRS.
Swapping from TRS to Bravo is a huge undertaking with the end result, a weaker drive.
![](http://i534.photobucket.com/albums/ee349/B-Diggity/WebsitePics/imagejpeg_3.jpg)
The trs is 2.5 iches longer like biggus said..But you do shed alot of weight I would say about 275/300 per side. The trans alone is about 125/150. I have done the conversion a bunch of times and every time a big difference in performance..two of them were mine. One was a 27 excalibur with the same motor and the x was 19.5 with the trs when i converted it to bravo I set it at 19 and i gained a best of 7 MPH. Boat ran a best of 80 with the trs and that was only once, then when a did a bravo 87 MPH and that was a bunch of times... My 10 meter I gained 6 mph and the boat handles way better. If you can do it yourself I would do it. A bravo boat will sell alot easier than a trs.. Just my 2 cents
