Timing jumped? >
Timing jumped?
Timing jumped?
Old 07-01-2002, 06:09 PM
  #31
Lee
Lee's Avatar
Tinker is right on.
Lee is offline
Old 07-08-2002, 09:06 AM
  #32
rjcardinal's Avatar
Hey Kaamacat!
Whats been going on with your engine. Had a chance to look at it again?
Inquiring minds want to know.
Ron
rjcardinal is offline
Old 07-22-2002, 08:38 AM
  #33
kaamacat's Avatar
How does thay saying go "It takes a big moron to admit their mistakes...." or something like that.
Well, after checking the wires, pulling the timing cover, checking the movement of every valvetrain component, taking the distributor apart (totally)........here we go.
I put it all back together, sounds a bit better but right when you drop to 1500 it starts to "cough/sneeze". (honestly). Got mad thinking this ain't right, its something simple. Went to check it again Saturday.................
.....followed each plug wire up to the left side loom, 1-3-5-7. Then checked the order on the cap. 1 3 5 7 ......All this and I guess i'm just blind or need to take my glasses to the boat.
5 and 7 were switched on the cap.
Here is the best part. I switch 5 and 7 back to "normal", just touch the key and literally cant stop the motor from starting. GREAT NEWS........NOW GET THIS.......I crank the enging just a few times so I can repaint the tdc on the balancer (and remember I said that NOW the damn thing starts almost by looking at it). Later in the day I go to adjust the timing and hear a nasty noise, from all of the problems the damn starter gear split. So guess Im off to the rebuild shop today.
So, what, 1month later, broken tools (and some new ones), countless bruises and some good old american blood, it was when i put on the new ignition stuff this season.
Bob 18436572 KaamaCat
kaamacat is offline
Old 07-22-2002, 09:05 AM
  #34
rjcardinal's Avatar
You see I told you it was timed correctly! The biggest myth in engine assembly is that when you install the cam with the marks aligned the distributor is firing number one. Its not really that big a deal because who stabs a distributor with the timing cover off to see the marks anyway? Just rotate the engine untill you feel compression comming out of the #1 spark plug hole then keep going until the balancer reads 0 then stab at #1 cylinder.
Im glad it was something minor. Its probably good you broke the starter gear while working on the boat and not on the water. Good luck and go run that thing.
So Tinker, Lee, and Bluethunder who is right now!
Ron
MILD THUNDER
27
08-21-2006 10:06 PM
trobertsuk
5
03-09-2004 06:22 PM
darkxer
Active Thunder
32
03-09-2002 07:47 AM
Quick Reply: Timing jumped?
