What RPM @ Idle
What RPM @ Idle
Finally fired my new engine the other day. It's a worked 454 with a pretty healthy cam in it. Seems to like to idle best @ 850 - 900 RPM. I'm wondering how the clutch assembly in an older Bravo (1990) is going to handle shifts at this higher RPM? I hear that the older bravo's have a weaker clutch assembly then the newer ones, and are not updatable. Is this true?
Thanks,
Scott
Thanks,
Scott
Can't help with the Bravo as I have TRS with transmissions, but my 454's idle 1000 RPM in neutral and 750-800 rpm in gear. Cams have 235/245 @0.050 duration.
With my cams, idle and shifting is very dependent on ifnition timing. I have MSD distributors with a short curve, so that I have 18* initial and 35* total advance. At less than 15* initial you can't put the trans into gear at any (reasonable) RPM without the motors stalling.
-Greg
-Greg
Pure Energy
12
10-03-2002 09:38 PM
