Corsa Silent Choice
I just got my boat back from the shop
But they said that they noticed that the port silent choice is not opening, but if you reach back and help it by hand it will open. Does anyone know how much and were to find a silonoied? Or what the problem might be, they said they checked power out and it is getting the full 12V..
Chris
Chris
Mine does the same thing on the port side only . Every once in a while it needs just a little help. It does it after the boat has set for a period of time. When I use the boat often, it loosens back up.
Registered User
It just needs adjusting. I had two out of four develop the same symptoms last weekend. I posted a thread and got some good advice, do a search under "Corsa Silent Choice Mufflers" or "Lickitysplit". I also called Corsa and spoke with Dennis. If they are like mine the piston comes out of the solenoid. It has about a 3/4 in. long piece of allthread that you can use to adjust the piston. I had one that would not open, I adjusted the piston forward out of the actuator. Fixed it. The second one was chattering in the open position, that one I adjusted the piston back deeper into the actuator. Fixed it. I fiddled with them for a while, dropped the spring into the bildge etc....the usual stuff. But they are both fixed and work fine. Corsa's number is on www.corsaperf.com.
Mike
Mike
