Power steering pump rebuilder
http://www.mercruiserparts.com/Show_...28849906A15%29 does anyone know of a source that can rebuild part #1 power steering pump for the 525 efi,if not what are my options,,,
it's still just a late model saginaw pump, take it to a auto parts store and match it up, then change the pressure relief valve and spring over from yours to make certain you maintain the same pressure, it's mounted under the nut where the pressure line screws in, just remove nut valve and spring will come right out, swap with yours and roll on...Rob
thanks ez,,,found out the power steering pump that will fit on the 525 efi,,,is for a 82-85 Cadillac Seville 4.1 Liter engine,,and i will use my old pressure valve
![Thankyouthankyou](/forums/images/smilies/thankyouthankyou.gif)
