KaKeifer Tabs/ K-planes leaking?
So my boat had a slight leak.
'after some hunting, i found that the leak was coming from around the cable indicator for the starboard side...
on the tab its self you can unbolt a big nut that holds a plastic clip,, and a rubber groument in there. water came out... so i put some 4200 in there and reinstalled everything.
anyone ever had that problem?
you probably fixed it with the 4200. if not, you can get replacements.
http://www.ebay.com/itm/SS-CABLE-GRI...s_Gear&vxp=mtr
