vortec timing
1 Post
fixx
There is no jumper wire to ground this distributor has a two wire pin connector that plugs into the module one wire pink the other brown ...what I need advice on is what type of hei works best for a stock vortex 5.7 with 600 Holley with throttle range to 4400rpm,,,,because this outlaw junk distributor just will not get the job done
http://www.performancedistributors.com/gmssdui.htm
Give DUI serious consideration. It's not MSD but most of us for normal use don't need all a MSD does any way.
