Ignition question
I would like to lock out my ignition on my bbc blower motor. I am using a MSD 6-AL box and a thunderbolt distributor with v-6 module currently. I know that this can be accomplished with a MSD distributor easy enough, but want to know if anybody has figured out how to merge the hall effect output of the merc distributor to the MSD box. I hate to buy an expensive "pick-up" when I already have one.....
Thanks.
Thanks.
Offshoreonly Advertiser
Brad, you can make it work, I am not sure if I remeber this correctly but I think one of the mag pick up wires (don't remeber which) goes to the R/W terminal (on the distributor), the white MSD wire goes to the G/W terminal. The only problem is that you will have locked advance.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
