525 fuel pump relay? Please Please help!
I am helping a friend start his boat. It will only run if we prime thru flame arrestor.it is a 2005 525 efi Checked easy things (water fuel separator)- i am thinking there may be a relay for electric pump? where would it be? please help us thank you
Charter Member #1171
There is a relay bank on the back of the motor,,,,it is on there
I want to live in a world where a chicken can cross the road and not have its motives questioned.
Its has a bosch relay that controls the fuel pump......I have even seen those marked for application,,,,,but just unplug one by one and cycle the key until the pump does not run
Just reread your first post,,,,,do you not hear the fuel pump at all????
this boat 05 Formula had a slight harness fire from mercruiser macathod or drive pump-we can run it w/fuel sprayed into flame arrestor-but will not run on its own-i do not hear the pump- also the fire suppression went off -is that tied into fuel supply in order to cut fuel to motors?
Check the tether as well, mine is wired to my tether, engine will crank and fire with tether but no fuel.
I think you might be on to something with the fire supression, makes sense. Why did it go off in the first place though?
Formula should be able to supply you with their wiring diagram, the merc one is available online. Link the two together.
