Tunnel Ram & 2 4's
#41
This would be bad azz, with a couple of the Holley billet 1000cfm TB's on top
Intake Manifolds - Chevy - Big-Block - Victor Series - Edelbrock, LLC.
Have y'all seen the new Holley Sniper sheet metal manifolds? They have one for BBC. Looks promising for marine, just wish they had an EFI version. Large plenum and even length runners.....They have plethora of single and dual 5150/4500 mounting options. Price is actually reasonable too, $470.
https://www.holley.com/products/inta...s/parts/835162
#42
Hope they are better than the fabricated one's for the small blocks. I think a donkey had sex with a chinaman and the mutant chinesedonkey kid designed and made it.
![](https://images.holley.com/825011_01.jpg)
#43
LOL....^^^^^^ what a turd
#44
That Eddy tunnel ram looks awesome and I have coveted it many times. Love how it is setup for port EFI already. I would love to run tunnel rams on my refreshed 502 if I stay NA.....but by the time you buy that pricey Eddy tunnel ram, top plate, two billet TB's, and fuel rails.....you could have just bought superchargers (used at least) and be done with it! Only thing I worry about with that is those ports look to have a mighty large CSA and would be lazy on a 502 or not match well with 320 heads.
#45
Is there any any talk on any of the other forums on this one. Your right the price isn't bad at all. I was looking the dart and profiler. Both pricey but good. I don't even wanna think about how confused I was at the time. Newer edel evidently good results also.
I ended up less ci due to going the blower route otherwise I woulda went 565 with TR.
SB your spot on. Lol....
what rpm you going after?
#47
Not a tunnel ram but I'd put it in a in btwn category. Equal runner length with two 4150's would be fun to try. Most single planes runners suck. Ideally longer the better however height comes into play with most real TR's. The best single plane I've seen is the brodix sr20. Tall deck one.
#48
I haven't been on holleys sight in a while but looks like their either spending some R&D time to to keep up with the competition or just making some slight changes to the little China men's and having them build to their specs and shipped over. Lol..
#49
Funny thing is, they are now selling the 102mm LS TB's that are all over ebay with only their logo on them. Looks identical otherwise right down to the thick throttle blade and fat shaft which disrupts major airflow. I bought one last spring and a 4500 to LS adapter elbow and we put it on Articfriend's chinesium intake 548 dyno mule motor. Norm even reworked it majorly as stock wouldn't even flow over 900 cfm on his flow bench. Killed significant HP over the chinese 4500 flange TB.
I do like the looks of the Edelbrock Pro-Flo XT intake, however I think the 92mm TB opening would be limiting factor......and a proper 102-105mm monoblade TB that actually flows is as expensive as a good 4500 flange TB anymore.
Now, if a TPiS Aqua Lung TB could bolt on the front of the Pro-Flo I'd think you'd have something there.
No matter what way you look at it, it's expensive haha!
