fuel pressure sender location
Hi, i have a 1999 7.4 mpi motor and wanna hook up a in dash fuel pressure gauge up to it. I looked around the fuel rail and only found the caped shrader valve in the front. anyone done this to know how to get this done? And if so, were do i buy the adapter to go on the shrader if thats were it gos
Some of those shraders are 1/8 pipe you could "T" off of that. If you need to adapt off of the shrader, buy a fuel pressure tester from a auto part store and use that adapter. The reality of it is fuel pressure is rarely an issue and you'd be better off keeping the tester in the glove box and spot check the motor if it's running goofy. One less place to leak fuel.
