cold water a bad idea?
Look at your insurance policy ,I think it says that you cant use your boat before a certain date up north and besides if something goes wrong and or if you hit something you will be up $hit creek without a paddle ------ No time to be in the water and a life jacket is only good to find your body !!!!!!
Jim
Jim
Jim
Jim
check for condensation in the oil , only prob ive seen . although I run with no t stat so engines run cold . as long as youre oil gets above 212 it will cook it out though , I wish I could gt some test time soon ,, congrats
But slower because the water is more dense.
and the trip will be short because you will be freezing your ballz off.
Wear a full face helmet, you'll thank me later.
Come on over to Clinton Lake. Nuke plant has the water a bit warmer than the river. You cannot get under the first bridge where the discharge is as that is roped off until April but from the Marina to the bridge will have water much warmer than the river. After all this rain there could be a bit of junk floating in the river as well.
