Merc 600's info?
JBK,
Are they trying to pass those off as stock Merc 600's? Get a serial number off the block and find out what those motors are. The only 600's I have seen were twin carbed. Merc used the 502 as the base for those motors. I'm not an expert on engines but guys I have talked to don't like running single carbs on top of blowers because the outside cylinders run lean.
Dan
Dan
speel chekk this fokker!
those blower looks like 250s with single carbs. i have heard its an ok setup with dom 1050 or bigger but dual carbs is much better. 420 megablowers are big ole things.
Pardon me, while I whip this out!
Merc 600 SC- 502 CID
GM engine code stamped in block, (last 2 letters) gen IV & V-- FJ or HJ
B&M Mega Charger model 420 @ 6 PSI ratio .93:1
2- 700 cfm Holley PN 80427
![Thumbs up](/forums/images/icons/icon14.gif)
candyman, puder, david - thanks for the 411. i have not questioned the owner about the discrepancies yet. i thought it was kind of funny though, all the research that i had done before i posted here, stated 502cu inch, dual 700's, w/ a 420 mega. puder, i think the blowers look like 250's as well.
thanks again. i'll keep you updated as to what i find.
chad
chad
