Propshaft Runout >
Propshaft Runout
Propshaft Runout
Old 04-14-2013, 04:34 AM
Ginger or Mary Ann?
US1 Fountain's Avatar
Its under warranty, send it back. Not sure if they'll repair or replace the unit as a whole. But it'll either give them the opportunity to look at the gears for that small chance of damage during a repair, or they'll be replaced if the unit is just replaced.
US1 Fountain is offline
Old 04-14-2013, 05:33 AM
You whacked a rock that hard and the skeg is still in one piece?
phragle is offline
Old 04-14-2013, 05:55 AM
Originally Posted by mike tkach
whats the harm in trying the hammer trick,if you make it worse,send it in,if you make it better,go boating.
phone call from warrantee manager : "hello, mr. psi ? we recieved your prop shaft back and it sure looks like somebody beat the sht out of it w/ a hammer ... "
mr psi : " [I]well... my buddies told me you would still warrantee it if i sledgehammered it a few times ..."
warantee manager : " sorry our warrantees don't include monumental willfull stupidity . just give us a credit card number and we'll ship your new one our right away "
stevesxm is offline
Old 04-14-2013, 05:58 AM
That will fix it.....
phragle is offline
Old 04-14-2013, 09:39 AM
How did you measure this runout, and at what point on the shaft?
This may be a given, but I'm new to measuring boat stuff.
Cole2534 is offline
Old 04-14-2013, 01:18 PM
While funny.... SEI will actually still warranty it.... They have a 3 year no questions asked warranty. I called them at the end of the season and told them I struck something and they said, it is covered just email is a picture of the serial number plate from inside the top of the housing.... They told me of I forgot to loft the drive and drug it up a ramp, they will cover that too.....
low_psi is offline
Old 04-14-2013, 01:20 PM
It was a freak thing I think. I am thinking it was a side impact. It happened as I was swinging the boat around in the marina canal, to put the bow into the wind. No damage, not even a nick to the skeg. But the prop is a mess.
low_psi is offline
Old 04-14-2013, 01:24 PM
Fast Singles Club
the deep's Avatar
Sorry brother but a true dead blow hammer leaves no marks on something hard like a prop shaft .
the deep is offline
Old 04-14-2013, 01:25 PM
I measured it with a dial indicator that was attached to an adjustable arm, that has a set of clamping pliers on the other end. I took the measurement on the smooth part of the shaft directly behind the splined area. Ideally I would have measured the runout at the end of the shaft, but I needed the nut on there in order to have something to turn the shaft with. So given this, .010" runout wear I measured, probably is even more out toward the end of the shaft..
low_psi is offline
Old 04-14-2013, 01:45 PM
low_psi is offline
