head stud nuts
head stud nuts
I need to replace my head gasket on my 502 MPI i used head stud instead of bolts. Can i reuse the same nuts and washer.
that is the main reason to use studs in the racing world,you can reuse the hardened nut on the hardened stud over and over and you are not stressing the threads in the cast block like you would if torquing a bolt ,the cast iorn threads will pull after enough torquing cycles.
