525 help
Fast Priorty II Nor-Tech
Down 500 rpm on star motor , sounds fine gages fine, idiles fine any ideas ? I can only get 4300 rpm top end . port 525 runs fine 4800 rpm
Forum Regulator
Prop in good shape?
Have you checked all of the plug wires and spark plugs?
Sounds like it is down a cylinder but toss a scanner on it first. Boat is way over-propped.
Plug wires look good , going to get the motor scanned. The props on the boat are original from fountain but are in fair shape i just purchased new merc lab 32's for it hopefully that will help after I get the motor sorted out. I think I lost a cyclinder also.
Forum Regulator
I just picked up the pigtails to play with my neighbor's 2013 40HP outboard as well.
You are going to drop $500 bucks, but it's worth it if you have to wait once or twice for 2 weeks to get a service appointment for a $50 sensor; even if under warranty.
Given the boats you have listed, IMHO it would be a strong move to pick up a Rinda scanner. www.rinda.com
Forum Regulator
I prefer the scanner over the laptop software as I normally take the scanner with me everywhere, vs. a laptop. It's ridiculously easy to use, just like a code scanner for your ODBII port on your car, except better.
If you can take a simple compression test, and make sure each hole is pretty close in pressure. Then run for codes.
