Shop crane help
Ginger or Mary Ann?
My brother and I built one in his pole barn. The one end is attached to one of the wall poles with plates welded to support the end that works like a hinge. The cross I beam we welded a pipe thru the center web on the end that located between the wall plates and simply dropped a rod thru to work as the pivot. The other end of the cross I beam we made a standard style gantry leg on wheels that will pivot under the beam. Swing the ibeam out from the wall and pivot the support leg at a 90 to the beam and used a power winch to pull my motors. The abilty to slide the winch on the trolley and swing the whole setup allowed for unlimited positioning. Raised the motor up, swing the whole thing towards the wall. Boat was on jackstands. When done, swing the ibeam to the wall, pivot the support leg so it's parallel to the wall and chain it in place. Only takes up 6" of floor space for approx 4 along the wall (the length of the support base frame). This design doesn't put any lateral force on the wall post, other than the weight of the beam and motor, straight down.
Perfect for where you don't want it taking up floor space when not in use. Mounted the beam on the pole so it just cleared the bottom of the trusses.
i perfer this style..http://www.overhead-cranehoist.com/c...op-167513.html
you can use it anywhere in your shop..
Sometimes you can get good deals at US Army Auctions in Anniston, Alabama and elsewhere.
https://www.dispositionservices.dla....anniston.shtml
Worth a look.
Give me a Call or Email me some photos of the shop. [email protected] Mike J 724*344*8429 I own a overhead hoist company
Originally Posted by [email protected]
I have a few 2 ton Jib crane for sale currently they are used and in great shape.
Charter Member #927
Charter Member #927
Most are 10' under hook height and 10' reach. 1 of them is 12' x12' reach.
