CMI Header bolt up
cmi header connection
Punk rocket,
I agree with Mr Cig you should not be leaking that far up the tail pipe.
I would remove the headers and bench test the header and tail pipe. I just encountered a similiar situation and upon the water test I found a crack in both tail pipes where they connect to the flange. It was a fine crack, had both welded, retested, and we were back running.
Post what you find.
thanks
Post what you find.
thanks
