Bravo goes Clunk!!!!
Charter Member #655
well you all heared that SuperV's drive took a sh!# as he was leaving for vacation.....what the heck can a drive take a dump at an Idle? I followed him into the ramp Sunday night and it was fine.A local guy told him that the shifter cable could be shot and its not going into gear all the way.....or something about the clutches ,what do the rest of you think?
If your boat has a sail do you ride a horse to the ramp?
Gone Fishin'
Dyno, is the drive off the boat?? If so, pull the shift cable out of the casing from the bell housing (you have to remove the two small set screws on the inside end of the shift cable at the linkage). See if it's bent/broke. If it is, I have one here. If it is the same size (they vary a bit in length) it's all Wades.
Charter Member #655
Mike Wade left for vacation as plannes found a room in T.C for $130 on the Bay .....He wont be back until early next week but I'll tell him you have one!!!!!Ever heard of that before?
