Chasing a 300-400 RPM drop issue in Port motor!!
#43
http://www.chevelles.com/forums/showthread.php?t=283185
Look at the post by BillyGman on this chevelle forum. I think I may go this route on both carbs so I can always get vacuum even in the future if I need quickly. Adding a permanent spacer is a no go. Completely out of room height wise.
#44
Just throwing this out there since you mention the one motor was down on RPM from day 1. gear ratio's in the outdrive the same in both sides ? Did not read the whole thread so just bringing it up as a possibility for lost rpm.
#45
Maybe all dominators are not created equal, but mine have a vacuum port under the primary side bowl.
#46
Blue, yes that is where I am going to add mine. Someone may have added that previous to you obtaining it. Just picked up everything to do both motors. Even got a new vac gauge I can actually read more than 5ft away....
BUP, both are 1:36 gear and 34 pitch B-1's
#47
Mine are dominators that came on merc 525sc, so maybe mercury did that. Let us know what you see with the vacuum gage. They are a very telling instrument, often overlooked.
#48
Will do. I do know that about every muscle in my body is either sore or bruised from the past week of jacking with this everyday. I don't give up easy! I cant thank all of you enough for the help....really thanks guys. I owe you all a 120 or hopefully a 130 mph ride when this is over!
#49
Have vacuum results:
Port (weaker motor)
Idle (1000-1050)- 9-11" fluctuating with lope
1400- 14"
1700- 16"
Starboard (Stronger motor)
Idle(950to1000) - 8-11"
1400- 13"
1700- 16"
Port (weaker motor)
1400- 14"
1700- 16"
1400- 13"
1700- 16"
