Low RPM at WOT
Low RPM at WOT
Hello there.
Gen v 502 efi's not going past 3900.
Plugged the engine up and got Code 33 from one engine and code 33 and 14 from the other.
When I looked these codes it was Manifold absolute pressure and water temperature.
What's your guys input as to where to start looking for the culprit?
I've already order some new rotors and caps and will redo the timing on the engine to see if that helps.
But or the mean time, what do those codes going off signify?
