What Is Best & SAFE Way To Disable 525 From Starting........
....so that I can check the compression while cranking it over with the key. No problems, I just want to check it. What compression numbers should I see?
Leak down test would be better but I did a quick compression test. With the engine slightly warmed up I got 90 or just a bit under on all 8. Is that OK considering the big cam in the 525?
Sh!t. Manual says 140#. Either my ancient Mac compression tester is off or I have a problem. All cylinders are equal though. :/ Engine was running strong.
