On-board-dyno
I am looking for a price, but can't find one.
If I already have a Stellings box, how much is it gonna take to get the kit with the retrofitted driveshaft (exchange, I presume), the wiring harness, and dsplay gauges?
I'm hoping for between $2300-$2500 depending on new or rebuilt used parts. Small volume is what hurts. So far, The guages are $169 each. Basically you pull the drive and then unbolt the driveshaft and then remove the bearing carrier and flange as one unit and replace it with my new or rebuilt assembly. Reconnect the drive shaft to the flange with the strain guage attached, install the drive, mount the electronic box, connect the wires, run the cables, mount the guages and go. I will buy back the parts removed ?$200. With time and volume hopefully the price will come down. Now mind you this all could come off and be transfered to another boat.
cobra marty
02-21-2002 05:26 PM
