Best flame arrestor
If you have 1000hp in a 24 Baja you are going to have your hands full, be careful.
I called K&N when I was looking to upgrade my flame arrestor as the Hardin I was using a sharp edge at the air horn. Based on their info the 9x3 would be so restrictive for me that it would pull enough vacuum to close my power valves. I went with a velocity stack style housing with the largest 14" K&N element. AT 5600 rpm I am still showing 0 vacuum so no restrictions for me. Most of the flame arrestors I have seen either are way to small or have serious flow issues due to right angles at the air horn.
So, I'll take this a step further and ask if anyone has seen any serious gains by removing the choke butterfly and milling off the choke housing on a Holley 800. Not much need for the choke butterfly in most marine applications - most of the time all you have to do is bump the throttle a few times to squirt some fuel in there and then just keep the idle speed up until the engine warms up a little.
632 if I can get 1.6hp per cu. in its over 1000. Problem is I'm building it under the wifedar. So I can't really spend the money to squeeze everything out of it. It will make 950 no problem the last 50+ will cost another 3-4 grand. Either way it will be to much for the boat. In good water the boat has been mid 90's with 850 in perfect water.
You don't happen to have a picture do you?
PM me and I will send you a photo.
Every modification is only as effective as it's necessity. Milling the air horn on an 800cfm carb on a 330 would be pretty ineffective, on a 572 it would be huge. Same thing with the flame arrestor, my 524 at 6000rpm needs lots of air.
