454 mercuiser MPI thermostat
Does anyone know if on a fuel injected 454 if you need to remove the intake manifold to get to the thermostat?
If not does anyone have the procedures to remove and replace.
Make sure get a factory (#5) 160 t-stat, the gaskets (#4,this you really have to make sure it's Merc as it has rivets to gound the t-stat housing) and 100% make sure you install the t-stat and (#6)plastic t-stat spacer/water flow guide the way it shows in this factory diagram or you'll f*k yourself. To put it blunt. Note how it is orientated.
