Baja 260 with 454.... Has mufflers and would like to remove them.....
So, I picked up this 93 Baja 260 with a 454 in it. The first time out I noticed it was considerably quieter than my buddies Scarab that had a 454 in it. Well, after I pulled it out of the water I was able to look up the pipes and noticed what looked like a muffler of some sort. Well..... I went ahead and investigated a little further once I got home and here is what's on it.
So, looking to see what my options are for removing these without spending a TON of money. I want to do it right, but just want to be budget friendly too. So, I guess I'd like to hear what my options are for doing this. Thanks in advance!
Thanks,
Kyle
Thanks,
Kyle
Thanks,
Kyle
No marine exhaust hose will not hurt performance.
The hose will replace every thing you have there including the couplers.
http://www.cpperformance.com/p-45-4-...aust-hose.aspx Prob need to order 3 foot.
side note, if you want to get rid of those I would like them if the price is right to test on my baja. I need to turn the volume down on mine
Go,with. The marine hose as stated and be done, just make,sure you have some type of flapper inside or out side
I believe that your internal flap thats folded down tjere is broken. It should be up, and there is another flap right behind tthat one that should be down like the one shown.
Ok, so my next question since I haven't dealt much with the internal flaps...... Are those internal flaps built in to the tips that attach to the transom? The tips that my external rubber flappers are screwed too? If I take a screwdriver I can pry that flapper up, but its stiff enough that I can't with just a finger.
