Could backfiring cause this?
#32
#33
My 1st thought was reversion on the one side the way the pistons are cleaned off. Oh and I cleaned out my inbox for PMs. I will look over the heads today.
#34
Not that I am seeing, there was water spitting out between the riser and the riser extension that is a dry joint. I removed & pressure tested the manifold, extension, and riser as best that I could but found no leaks. I tore down the short block tonight but haven't looked it over yet. I will post some pics tomorrow.
#38
Weird discoloration on the journals, looks like the rods were hammering on it
#39
I am questioning whether this crank is some brand of Chinese junk & if it would be worth it to try to polish it or make another door stop & find a chevy crank. Tried to remove the harmonic balancer & stripped the threads on a brand new puller. And yes I removed the center bolt first in case anyone was wondering. Lol
#40
randy,what is the part # on the rod bearings,from the pic they look to be a p bearing and thats no good if you have a crank with a bigger radius on the journals,it restricts the flow of oil from exiting the bearing and boils the oil.
