Could backfiring cause this? >
Old 07-31-2014, 12:09 AM
  #41
Randy Nielsen's Avatar
I will take some pics of the piston-rod assemblies tomorrow.
Randy Nielsen is offline
Old 07-31-2014, 05:43 AM
  #42
F-2 Speedy's Avatar
Received 3,223 Likes on 1,439 Posts
I agree with Mike, looks like heat checking to me, a good std std GM fordged crank may be in order, and Randy we knew u pulled the bolt first.
F-2 Speedy is offline
Old 07-31-2014, 07:36 AM
  #43
just fyi,gm bought the gen 5&6 cranks from scat.
mike tkach is offline
  #44
couple of things...need to have a machine shop ck the crank for size/round and the rods as well, I have run into scat and other cranks that say factory balanced be totally crap and have a tuff time getting them to balance at all, can't imagine what they would be like run as is...backfiring had nothing to do with the bearing/vibration..good luck Rob
ezstriper is offline
Old 07-31-2014, 07:52 AM
  #45
F-2 Speedy's Avatar
So a Kellog stamped crank is from Scat ?
Old 07-31-2014, 08:28 AM
  #46
when you see that shade of gray,,they're all from china.
scat cranks are usually alright,a touch on the high side but have been way better than eagle.
sutphen 30 is offline
Old 07-31-2014, 08:33 AM
  #47
F-2 Speedy's Avatar
Yes, Im aware of that, but it didnt answer my question
Old 07-31-2014, 12:48 PM
  #48
[ATTACH=CONFIG]527218[/ATTACH][ATTACH=CONFIG]527215[/ATTACH]
Attached Thumbnails Could backfiring cause this?-20140731_122736.jpg   Could backfiring cause this?-20140731_122726.jpg
Old 07-31-2014, 01:04 PM
  #49
[QUOTE=Randy Nielsen;4160844 The crank was replaced & short block built 5 yrs ago then stored until last yr then everything disassembled cleaned up & reassembled, dyno'd now this.[/QUOTE]
I must have missed this.from the markings on the bearings,this crank/bearing clearance is a miss.
do you remember measuring this crank and adjusting bearing clearance.
  #50
yeah,I don't know that,,maybe RMbuilder can answer that
