Low oil pressure in brand new 502 efi
I purchased a brand new long block 502. Only second run out on it and it's showing I have Low oil pressure , checked the gage and the oil is fine, any suggestions?
you sure you put the oil lines on right.outside line goes to the outside of the oil filter pad.
What kind of new long block? If it is of the automotive type, the bypass in the filter pad is probably an 11 lb unit and is not setup for a filtering system with a cooler. You will need to swap that over to a 30 lb bypass before you roast the bearings in the motor.
All good answers. How low is the pressure and at what rpm? Brand new automotive long block or marine long block? The marine block will have the 30lb oil bypass valve in the block under the oil adapter and an automotive has only 11lb. If it has the 11lb bypass, the oil will at some point not get filtered or cooled.
MATT, we must have been typing at the same time. Great minds think a like!
Charter Member #1171
Define " low " also,,, at idle or ,,, running ????
Nevermind,,,, 3 people said the same thing at the same time
I want to live in a world where a chicken can cross the road and not have its motives questioned.
