K&N Flame Arrestor for 7.4MPI
there is a big clamp on the plastic flame arrestor loosen it and wiggle the old one off and slide the new one on and tighten the clamp thats it about 3 mins worth of work
If yours is like mine then you have to remove the old studs with double nuts or vise grips and install the new adapter with the supplied allen bolts and then clamp down the filter clamp,btw mine is a 502 mag mpi
Rick,
I got the flame arrestor from Martel Brothers... it's a performance shop in Katy, TX (close to where I work.) They also are one of K&N's bigger on-line sales sites... www.martelbros.com. It is the marine certified, race/off-road use only, flame arrestor. (Part 59-5004)
Do I have to pull the plastic engine cover off to get to it? Do I have to leave it off to make the K&N fit?
Thanks!
