Hp 500 carb setup help >
Old 09-11-2014, 02:40 PM
  #71
Originally Posted by jiffy292
Thanks unplugged knock sensor and it ran right for the first time was able to turn 5k and cruise at 3500 no surge for a few miles. Then on the way in it started again. In the process of swapping ign modules i unbolted the coil and move it around to get in there, swapping couils it the only think i have not done yet. will try a new coil and see what happens. I dont think there is anything left! I have eliminated just about everything.
This is about the time I would've just given the boat away in frustration to have the new owner find a loose ground wire. Keep at it!
Baja Rooster is offline
Old 09-15-2014, 07:08 AM
  #72
jiffy292's Avatar
Narrowed it down to a bad coil!
jiffy292 is offline
Old 09-15-2014, 09:07 AM
  #73
SB
Received 3,277 Likes on 1,467 Posts
Well, that was an azz kicker !
So, (just confirming) you installed new coil and it runs perfect now ?
SB is offline
Old 09-15-2014, 12:02 PM
  #74
Will you be selling the holley 850 ?
MILD THUNDER is offline
