single plane intake vs. dual plane
Reason for asking - the carbed version's have a high rise GM intake. The MPI's have fuel injection, and yes, if you convert to carb with Holley 800 or so and a good aftermarket high dual plane you will gain power. With it's dinky lame azz cam, a HR dual plane with work well.
Which 502 Mag ?
Charter Member#568
If anyone is interested and can post it I can send you the dyno graph of my carbed 540 with 315 AFRs and vic Jr.
Straight bottoms and flat decks
Don't forget about the tunnel ram guys. The old myths about them have been smashed time and time again and a properly tuned tunnel ram will increase the air flow of the cylinder head...
The only time I have flowed an intake and recored a increase in the flow of a cylinder head is with a realy well designed sheet metal intake, most still loose a bit. A well ported cast intake of any type or out of the box drops aiir flow through the head.
And your point is?
No it does I've seen it done on a flow bench. It's been a couple years since I've seen it and honestly at that time I really wasn't interested in it @ .500+ lift the head started gaining with the tunnel ram on it not much but it started gaining. I kinda dismissed what I witnessed on my buddies bench until about a year ago. I started looking into tunnel rams. I called all kinds of cylinder head guys alot of them said yes if done right the will pick up some said no they will not. They are called a tunnel ram for a reason...
