Antifreeze for Winterize Mercury 700's?
New boat with twin Merc. 700 SCI's. I am going to do first winterization and not really sure that I should run antifreeze through the raw water system. Manual says optional. The engines have the original stock headers which do not leak(as far as I know) but I want them dry and do not really want to drain antifreeze into the bilge which is pristine white. I like to over do things, but I think just going to run the fogging solution and drain the raw water systems. Thinking right or wrong?
Your Latitude provides you some level of protection, I used to use RV anti-freeze until I discovered it gells in the water passages. I now drain everything and pour a small amount of automotive antifreeze in to mix with whatever water is remaining. It's hard to get all the water out of the block and oil cooler. I keep my boat in a heated garage, but if my furnace quits, the outdoor temps are in the serious negative range where I'm at.
Wrong...even if you drain the raw water system and blow it out with compressed air (as I do), it's nearly impossible to get all of the water out. Any of that water freezes inside coolers or other components and bursts something, you will be a very unhappy camper. You should be able to put a small bucket under the drain plug on the headers to catch the antifreeze so it doesn't run into the bilge when you drain it. If not, you probably could get a big funnel, attach a hose and let that run into a bucket or run the hose through the drain hole. Either way, don't short change the winterizing process...
Thanks for the opinions. I'll do it right with the antifreeze and sleep better at night. I use the Extreme Bilge heaters in my boats anyway. But I have to prep for the rare power outage. The bilge heater is a nice piece for everyone. It is USCG approved with a thermostat. It seems to help reduce condensation and corrosion in the bilge. In KY we constantly see saw above and below 32 all winter.
