Carb to EFI
I upgraded to EFI on both my motors, bout some used FAST EFI systems, holley single plane intakes, 1000cfm throttle bodies off EBAY, and some Walbro 255LPH pumps. I will never go back to carbed! I had Holley on my drag car, really nice set-up. You can use a RACEPAC dash with some interface modules and have the top dog. For you, the Holley HP will work perfect, and will do more than you need!
Price is yet to be determined. The 1000cfm kit is around 2800 or so. Without a fuel pump and injectors. the injectors are around $350. I have not decided on a fuel pump yet, not sure which direction to go there. You also have to factor in anything related to ignition system. Crank trigger, cam sensor, ect.. I can post a far more accurate figure when I get more into the prohject.
Went coil on plug as well, batch fire per Alex's advice. Bought Delco D585 high output LsX coils and 58x wheel. Buying some other parts a la carte. A big thanks to gimmefuel! Gave me the inspiration for ditching my distribitor in the first place.
![Wink](/forums/images/smilies/wink.gif)
Did one using older style gm coilpacks from the northstar set up with the omc distributor delete stub.on a gen 5 put the coils on the bellhousing just loved it when people went whoa ! No distrbutor !
