Dyno proven 675-700 HP 540CI recipes?
#72
HAHA yes, ok, because I hacked it, cheated the cost, lied about hiding things to sell to someone and try to pawn hacked work to a buyer, not even the same thing pal....call it what you want and hate me all you want, you and I know this should not be an issue, and if you wanna fire it up go for it, I in no way did what the other person did .....in the end I am boating, the boat is MINE, not some guys to fix and hope to sell so call it how you want...
#73
at what rpm? what hull? heavy od TRS Cig? or Bravo stepped boat??? think about it....put these in a stepped hull see how they run I bet they hit 5800-6000
#74
#75
It's only 5 degrees more than a 525EFi cam...."too much cam"...jeez.
#76
Weren't 540 because all my parts were new over old stuff including blocks I didn't want to bore them and have bad rod angles, I know it's less cubic inch but man if that killed me that much that's insane...
#79
572cid.
Does that now sound bigger ?
It's only seven more than 565.
25 is much bigger than 7.
Weird how the mind plays games.
Huh.
Huh.
