Dyno proven 675-700 HP 540CI recipes? >
Old 07-20-2015, 07:42 PM
  #81
Originally Posted by JRider
Bore doesn't change rod angles
Mind you, I'm talking motors here not fountain skanks. Rod angles change drastically with a big bore fountain skanks
JRider is offline
Old 07-20-2015, 07:45 PM
  #82
Just when it was getting boring in here. Lol.
Would be nice to see fuel flow/consumption.
Cole2534 is offline
Old 07-20-2015, 07:46 PM
  #83
Oops on the plural skankers...half price edmond Fitzgerald beer gets the best of me.
JRider is offline
Old 07-20-2015, 07:50 PM
  #84
SB
Received 3,226 Likes on 1,456 Posts
Thanks for the clarification. Bent rods perform better with Ms Brittany Fountain Skank. In fact, they have to almost go in sideways as There is no piston, even custom, that will fill that bore.
SB is offline
Old 07-20-2015, 08:00 PM
  #85
Mr. SB, I respectfully disagree. This, inverted, fills the cavity nicely and even has a handle for easy retrieval...
phragle is offline
Old 07-20-2015, 08:06 PM
  #86
articfriends's Avatar
Have you tried any other props to see if it can pull any more rpms and get you closer to the power band IF it is up there higher? IF power curve shifted up a few hundred rpms and you had as much prop as boat could possibly pull previously maybe you have hit a point where it needs to rev a little more, just a thought, hope you find some resolution, I would think the tq band overall would be fatter but maybe not?
articfriends is offline
Old 07-20-2015, 08:13 PM
  #87
Throttle Fever's Avatar
Reason to ask lobe overlap is a prime key to big power numbers, but only if your are running good exhaust. Have ever heard that an engine needs a little backpressure, you might want to ask yourself why an engine would want an exhaust system that literally pushes exhaust back into the combustion chamber rather than sucking it out. The simple answer is, it doesn't. If a big-overlap, big-cammed engine has an exhaust system with any measurable back-pressure, the price paid.... big drop in output. That said that is a big cam, for a 5400 rpm engine, 6000 rpm engine, ok.
Looks like helping the OP on this post is not the point so I will exit, experts carry on...........
Throttle Fever is offline
Old 07-20-2015, 08:18 PM
  #88
Full Force's Avatar
stroke does, my old cranks were 4.375
Full Force is offline
Old 07-20-2015, 08:20 PM
  #89
Full Force's Avatar
that's next step and reasoning, I have pretty much come to conclusion the old engines just were stump pullers and these need the rpm....
Old 07-20-2015, 08:22 PM
  #90
Full Force's Avatar
I run stainless marine dry to the tips..
