What oil pan is this???? Gen6 bbc
#31
Full Force, if you could ask your bud if he has some Gen4 pans, thanks in advance, 10 qt be great, Gill or whatever.
#32
That looks like someone copied the old gen 4 stamped kickout 10 quart ,look at how the dipstick tube attaches compared to a crate motor 6 quarter.slim Pickens for the gen 5 and 6 guys for stamped ,outside of oe. Had a guy in jersey fab me up some 502 pans once ,low profile front sump app ,only does aluminum ,from scratch want to say it was around 500 or so each .check your starter clearance before you get real exited ,usually have to change a few things there with big dog pans if you don't want to pull motor to pull starter unless your Gumby
#34
4.530x4.375
Can also get displacement by 3.14 x radius2 x stroke x number of cylinders.
#35
#36
1 pc rear main gen6 https://www.google.com/shopping/prod...ed=0CDwQ8wIwAA
[ATTACH=CONFIG]535096[/ATTACH]
#37
Be careful of crankcase pressure pushing the seal out. In case you have an issue, that you think you can fix quick, just check the seal. Bit me in the ass last summer
