049 oval port heads
Maybe. The deck and head surfaces don't always match up that well and they will leak coolant into the lifter valley. I have a set of 049's on a gen v block, I made a paper template of the heads and water passages and matched it to the block to make sure they would seal.
14097088 1991-up 454/502
The part number above is what your long for
And for future reference,here's a list of the castings
http://www.minuit10.net/EngineCode/c...linderHead.htm
Put alot of 049s and 781's on gen 4 454s with reasonable cams and they pull great to 5400 or so .
its been on my bucket list since gas was a buck a gallon to swap some peanut ports with 049's on mercs "310 at the the prop" gen 5 and see what happens, there are gaskets just for that swap but you still should confirm it aligns properly .and no edelbrocks with adapters please on your induction change up
Yes, there are gaskets that work, but you can still have an issue. The problem is the difference in the water passages on the head and block. All the castings are not exactly the same, some have them in the right places that allow at the gasket to crush and seal, others miss and you will get no crush and leak into the valley. The ones that make it are very close.
Yep . No dirty casting flash in your heads , measure mating surfaces with a real straight edge , tee a gauge next to your t stat and keep it a clean 12 psi or so at full boogie , and pop your block plugs and suck the sand and silt out of the bottom if not done already , and go enjoy some healthy midrange punch
