How much does weight matter? >
Old 02-10-2015, 02:03 PM
Not only will the given weight matter it will also depend on where the weight is. If you and or remove a given weight from the rear of the boat the effect should not be as drastic as adding or removing the same weight from the front of the boat. I try to keep everything that I can toward the rear or at least behind the center of gravity.
GETTINBYE is offline
Old 02-10-2015, 03:55 PM
I need to go on a diet, I may be able to gain 2 mph!
stimleck is offline
Old 02-10-2015, 04:37 PM
Fast Singles Club
the deep's Avatar
Remember that sea water is denser and weighs more than fresh water .
the deep is offline
Old 02-10-2015, 04:40 PM
SB
Received 3,277 Likes on 1,467 Posts
And sea water is at sea level.
Believe it or not, many forget about that performance advantage in of itself.
SB is online now
Old 02-10-2015, 05:09 PM
Originally Posted by drpete3
If I didnt take 800 pds of beer I could hit light speed.
Problem is I can hold it forever. No net gain
abmotorman is offline
Old 02-10-2015, 05:18 PM
Originally Posted by Sydwayz
Aerodynamic drag and hydrodynamic matters too. We can get another 1-2 MPH out of a 37AT just by playing with or removing the windscreen.
Swapping from 280 tabs to 380 tabs, as well as adding normal load tools, spare parts, anchors, lines, fenders, spare fluids, two extra batteries, and a fair sized stereo...
...is taking 3-5 mph off of my top end pending water conditions. I don't care though. I'd rather be prepared than chasing every last decimal point on the GPS speedo.
Remember:
Water: 8 lbs. per gallon
Fuel: 6 lbs. per galon
Sydwayz, I know we are talking about weight in this thread...but did you see a performance decrease using 380 tabs vs 280? Dont want to start a whole thread just for that.
turbo rr is offline
Old 02-10-2015, 05:58 PM
Forum Regulator
Sydwayz's Avatar
Received 1,263 Likes on 551 Posts
I almost always run my tabs neutral. The length difference between the 280 and the 380 alone is enough to scrub a few 10th if not a full tick. If I was running a kilo, I'd likely take them off entirely.
Sydwayz is offline
Old 02-10-2015, 08:31 PM
Thanks not sure if i want to make the jump to the 380's.
turbo rr is offline
Old 02-10-2015, 09:52 PM
On the other end of things, rotating mass is another weight issue. Loosing weight in the drivetrain = more HP. Just costs a lot!
kevinb230 is offline
Old 02-11-2015, 12:31 AM
On the other side of the coin, heavy wave crushers, while slower, tend to ride better than ultralight potato chip boats...
phragle is offline
