Fuel Pump
https://www.holley.com/products/fuel...arts/12-454-25
These are what I run. Pre-set 7.5psi pressure. 170 gph. I still use a regulated return system back to tank.
Is there any good way to bench test these pumps? I have one of the old Holley six-valve versions - was working fine when I took it off my old 454. I did notice that the lever is damn well impossible to push down manually - are they all like this?
Yes. Extremely hard to pushdown.
I have a Clay Smith 6 valve pump and it wears down the push rod pretty quick. It to is very hard to push the lever down.
Yes, I just throw a new push rod in at the beginning of the season. If I let it go too long it makes it too hard to get out. Also I don't want it to dig into the cam.
